I thought NGons should be avoided but it seems that when using the knife tool it's unavoidable that they are created.How i…
Forum Archive I thought NGons should be avoided but it seems that when using the knife tool it's unavoidable that they are created.How i…
  • #3857
    Carkoon
      I thought NGons should be avoided but it seems that when using the knife tool it’s unavoidable that they are created.How is this dealt with?
      #21796
        You need to “clean up” n-gon-generating knife cuts by cutting new edges to convert n-gons to 4-sided or at least 3-sided polygons.
        #21797
        Carkoon
          Thanks. Should you do the clean up immediately or after the model is finished?
          #21798
          Liam Silcox
            There’s usually no reason not to do it immediately. they can cause a problem with the sub-surface modifier which you’d use for a lot of projects to give it that smooth appearance.
          • The topic ‘I thought NGons should be avoided but it seems that when using the knife tool it's unavoidable that they are created.How i…’ is closed to new replies.
