I opened to many animation tabs on the bottom
Forum Archive I opened to many animation tabs on the bottom
  • #11496
    enzopalmer27
      How do you close the animation things on the bottom if you don’t want them there?
      #53637
      Mark Smith
        with your cursor in the window above what you want to close, move the cursor to a lower corner until it turns into crosshairs…
        then left click and drag down toward the window you want to close… the cursor will turn to a downward arrow, then release the left mouse button…
        repeat for each window you want to close
        hope this helps
        #53638
        Shawn Blanch
          You can also right click when the cross hair shows up and it gives you a few more options.
        • The topic ‘I opened to many animation tabs on the bottom’ is closed to new replies.
