I keep getting "circular reference in texture stack' error, cannot bake normal map, smoothed both high and low poly object…
Forum Archive I keep getting "circular reference in texture stack' error, cannot bake normal map, smoothed both high and low poly object…
  • #6127
    sunridersinc
      I keep getting “circular reference in texture stack’ error, cannot bake normal map, smoothed both high and low poly objects. Found a hint on some forum to uncheck ‘N_bake’ texture assigned to low poly object in properties/textures, this helped to bake a normal map, am I doing something wrong?
      #24947
        Yes, I would say you’ve got something wrong in the setup as I rarely get that error. I’m not sure exactly what it is – I recommend re-watching this video and double checking your setup.
        #24948
        gsteigert
          In my case I had a material assigned to the low poly object. Deleting it and rebaking the normals did the trick.
          #24949
          Rozalia
            I had the same problem, deleting material helps, thanks!
          • The topic ‘I keep getting "circular reference in texture stack' error, cannot bake normal map, smoothed both high and low poly object…’ is closed to new replies.
