I have the same issue with every one else, when I duplicate the blade and set it to 70 degrees my newly created blade cha…
Forum Archive I have the same issue with every one else, when I duplicate the blade and set it to 70 degrees my newly created blade cha…
  • #5699
    inkplay
      I have the same issue with every one else, when I duplicate the blade and set it to 70 degrees my newly created blade changes its y axis rotation a bit so its at a weird angle. I have no idea why and how to fix it.
      #24208
      Darren McBain
        you could have a look and ensure you are in top down camera mode eg camera looking down the Z axis.  so when you rotate around it would use the camera view axis and use the perpendicular plane for rotation.
        or if your in another perspective mode, when rotating you could select the axis to rotate around, so pressing to rotate, then press (to select rotation axis) and then type in 72 and press Enter.
        hope that helps a little bit, just learning myself.
      • The topic ‘I have the same issue with every one else, when I duplicate the blade and set it to 70 degrees my newly created blade cha…’ is closed to new replies.
