I have the 2 cubes, of the rim, selected, with 1 rotated & use Object: Make Links: Obj Data, the top rotates to the unrotated position to make the other cube. I am missing something, but what?
Forum Archive I have the 2 cubes, of the rim, selected, with 1 rotated & use Object: Make Links: Obj Data, the top rotates to the unrotated position to make the other cube. I am missing something, but what?
  • This topic has 2 replies, 3 voices, and was last updated 6 years ago by mekg.
  • #8853
    crispalomino
        Did you rotate the second cube in object mode or edit mode? Rotating in Object Mode should maintain the rotation after making the link.
        #29507
        mekg
          I have a same problem. I know you don’t need an answer anymore, but it might help others.
          For this to work correctly, you don’t need to change the origins.
        • The topic ‘I have the 2 cubes, of the rim, selected, with 1 rotated & use Object: Make Links: Obj Data, the top rotates to the unrotated position to make the other cube. I am missing something, but what?’ is closed to new replies.
