I have questions about armatures. How do you remove clay from armatures? Like monster clay I want to reuse. Does the armat…
Forum Archive I have questions about armatures. How do you remove clay from armatures? Like monster clay I want to reuse. Does the armat…
  • #4182
    Norman Thibeault
      I have questions about armatures. How do you remove clay from armatures? Like monster clay I want to reuse. Does the armature stand become part of final
      sculpture?
      #22083
      Lisa Schindler
        Hey Norman!
        Monster Clay – like all non-hardening clays – can be reused. You simply pry the clay off the armature once you’re done molding your piece.
        The armature does not become part of the final sculpture, unless you don’t want to make a mold but want to keep the sculpture, then obviously the armature will remain encased in the clay.
        If you use Polymer Clay or an air dry medium, which transforms into a permanent sculpture either by being baked or by being exposed to air, then with those mediums the armature will become part of the final piece.
        Lisa
      • The topic ‘I have questions about armatures. How do you remove clay from armatures? Like monster clay I want to reuse. Does the armat…’ is closed to new replies.
