I have found a way to use Grease Cut reliably with Blender 2.79
Forum Archive I have found a way to use Grease Cut reliably with Blender 2.79
  • #11518
    Marc Andre Fortin
      Hey guys,
      Like many others here I could not use the Grease Cut tool with 2.79, the cut worked but I had to remove the other half manually.
      For some weird reason, when I rotate the model in edit mode on the Y axis by -90 degrees, and then rotate it by 90 degrees in object mode (for a total of 0 degrees on the Y axis), it then works for any base mesh.
      You still have to select the “Object” option in Grease Pencil Layers, and now use the Z axis for symmetry.
      I am using Blender nightly build blender-2.79.0-git.e045fe53f1b0-windows64 with the modified version of the add-on provided by Kent.
      Hope it helps someone!
      #53706
      Mark Smith
        good thing to know, thanks for sharing…
        #53707
          Thanks for sharing this tip @grossepoute !
        • The topic ‘I have found a way to use Grease Cut reliably with Blender 2.79’ is closed to new replies.
