I have been experimenting with the UV mapping options, and when I start with a basic cube model and select 'Follow Active …
Forum Archive I have been experimenting with the UV mapping options, and when I start with a basic cube model and select 'Follow Active …
  • #4517
    Nathan Walker
      I have been experimenting with the UV mapping options, and when I start with a basic cube model and select ‘Follow Active Quads’ the UV map that is created is much bigger than the 1024 x 1024 px square of the canvass. I tried painting on the ‘tabs’ of the unwrapped box, but since they are outside of the canvass area, the painting tool doesn’t affect them. Should I try to somehow shrink the UV quad to fit within the square canvass? Or is there another way to paint on these surfaces in UV view? Thanks!
      #22691
        You can simply select all your UVs and scale them down to fit within your canvas. Alternatively you can use the “Pack Islands” tool but this will move your islands around for an attempt to best fit.
        #22692
        Nathan Walker
          Perfect! So, I didn’t see the Manipulator tools in the UV Editor’s bottom menu (ie. as they’re positioned in the 3D Viewport’s Menu), so I assumed we couldn’t transform the UV geometry. But I see them up in the UV tool bar now. Thanks so much Kent, I appreciate the reply! …I’m also going thru some of your other vids, and I have a question about the ‘Baking’ process, but I think I’ll just tackle one learning curve at a time 🙂
        • The topic ‘I have been experimenting with the UV mapping options, and when I start with a basic cube model and select 'Follow Active …’ is closed to new replies.
