i dont know why but the baking is not working
Forum Archive i dont know why but the baking is not working
  • #13250
    itamar84
      i have followed this tutorial every step but i can’t seem to get the baking to work it gives me a  transparent image btw its my first time baking so i might have missed something obvious
      additional info:
      my specs are ryzen 2700x  16gb ram and a gtx 1070 ti
      so i think my pc should handle it
      thanks in advice and merry christmas
      here is the project file
      https://drive.google.com/file/d/1a-HmlX6niVoQrrAB3A1xXDI9S9WsDhRz/view?usp=sharing
      #62121
        The link to your file gives an ‘Access denied’ error. You need to tell Google that everybody with the link can access the file; this is no longer the default!
        #62122
        itamar84
          okay i think i  fixed it the google drive i mean not the baking
          #62123
            The link works now 🙂
            You are baking the Emit Pass, but there is no Emission Shader in your Node Tree. You need to plug the Displacement (in this case the Math Node) into an Emission Shader (or Viewer Node). You can disconnect the Principled Shader and the Displacement (from the Displacement socket in the Output Node) like this:
            Make sure the Image Texture Node where you want to bake to is selected and press Bake.
            (In the video Kent mentioned this at 3:45)
            I’ve tested it on a 32 bit 4K map (because my computer couldn’t handle the 8K image) to make sure that you didn’t make any other mistakes and it seemed to work all right.
            #62124
            itamar84
              thx it worked
            • The topic ‘i dont know why but the baking is not working’ is closed to new replies.
