i do not see any vertex showing when I ctrl+right click (Blender 2.79)
Forum Archive i do not see any vertex showing when I ctrl+right click (Blender 2.79)
  • #13375
    Jonathan Nunez
      i have the same configuration,so when i try to CTRL+right click
      #62597
      bitbuilder
        Are you in vertex selection mode? 1 on the number bar.
        #62598
          In 2.79 Blender used right-Click-Select by Default. In that case, you should: (select a Vertex, when you want to extrude it,) move your Mouse Pointer to the desired position and then press CTRL+LMB.
        • The topic ‘i do not see any vertex showing when I ctrl+right click (Blender 2.79)’ is closed to new replies.
