I couldn’t make the bavel modifier
Forum Archive I couldn’t make the bavel modifier
Viewing 7 posts - 16 through 22 (of 22 total)
  • #85445
    shresth vashist
      well, i tried and merging everything but nothing seems to be working. I also solved a mesh issue i had where it was overlapping a button but even after that it did not work.
      #85446
        There is probably multiple wrong things going on. Usually you could upload your file and we could go into it and fix things and point out what’s wrong. But I think it’s much more advantageous and fruitful if you start again from scratch, start over, al the way from the beginning. Your brain will sound an alarm trying to convince you that it is crazy, but trust us, start over. You will get a better result and you will learn from your mistakes, you will gain speed and the second time around you will notice so much stuff you took for granted and you’ll be like ooohhhh ok, I get it now. I’d say give it a try.
        #85447
          …or you could do both,
          upload your .blend, so we can point out where things went wrong, and then start over (it really really is very good practice to start over!).
          #85448
          shresth vashist
            okay i can do one thing that is i can upload the blend file here so i know what mistake i made and then start over in a new file so i dont make the mistake again.
            here is the drive link to the file: https://drive.google.com/file/d/1fU15bt3Z6gExjnUCs0Wqm9O-RWDI2lfz/view?usp=sharing
            #85449
              Beveling works fine:
              You will need to do some clean up:
              You have some inconsistent Normals: in Edit Mode Select all (with A) and then SHIFT+N.
              Also the bottom of your console needs to be re-aligned:
              and then you”ll need to Merge By Distance again.
              There are probably some more modeling mistakes, so I’d really recommend to start over, but that’s up to you.
              #85450
              shresth vashist
                Yup i will be starting over. The bevel still does not work though haha. Don’t know whats happening
                #85451
                  | “The bevel still does not work though…”
                  Did you check the Amount in the Bevel Modifier? (I used 0.05cm in the above screenshot and it’s clearly working…)
                • The topic ‘I couldn’t make the bavel modifier’ is closed to new replies.
