I can't seem to change the 'ball type' in the UI panel – all I can do is hide the different types in the ouliner which is …
Forum Archive I can't seem to change the 'ball type' in the UI panel – all I can do is hide the different types in the ouliner which is …
  • #5898
    lordgert
      I can’t seem to change the ‘ball type’ in the UI panel – all I can do is hide the different types in the ouliner which is a bit of a pain when animating it…
      #24532
      Wayne Dixon
        Thanks lordgert, we’ll look into that. There might be an issue with the file.
        #24533
        mam711
          I’ve never gotten the script to work, but could deal with it with previous animations. Now, with the multiple balls exercise, I can’t get the ball to stay where I’ve set it. As soon as I try to move a ball, it changes back to a basketball, and everything’s visibility is turned on in the outliner.
          #24534
          David Frazier
            Neither can I change the “ball type” sin the UI Panel. Plus whenever I select 1 of the 4 tans (Root, Body, Squash, Spin) the UI flies all over the place , AND does NOT even select its respective counterpart (If a click “Squash” it highlights in the tab but does nothing to the squash controls in the viewport. This exercise is quite glitchy, so much so that I can’t continue until fixed. Using 2.77
            #24535
            yithpistol
              Got the script running, but cannot change texture with the script, sad to say.
              #24536
              Wayne Dixon
                Try pressing ‘reload trusted’ in the info bar and have ‘auto-run-python-scripts’ in the user prefs.
              • The topic ‘I can't seem to change the 'ball type' in the UI panel – all I can do is hide the different types in the ouliner which is …’ is closed to new replies.
