I cant see assigned key frames
Forum Archive I cant see assigned key frames
  • #11673
    hrishi
      I cant see assigned key frames in general tab.
      #55755
      Wayne Dixon
        Hi @hrishi,
        I’m not sure of the exact reason for why you can’t see assigned key frames – but you might want to checkout out this video.
        https://cgcookie.com/lesson/keyframes-and-channels
        or the video before that one (called Timeline)
        Without knowing the exact issue you’re having, I’m going to guess and say there’s something in those videos that will solve your problem.
        (It might be as simple as your object is not selected?)
        If you are still stuck. – post a screen shot or the file.
        Hope that helps.
        #55756
        kenniswong
          I had the same issue (when I pressed “t”, I got an error message saying “Keying set failed to insert any keyframes”). In the lower-left corner, there’s a “keying” dropdown, and I removed the “Active Keying Set” by clicking on the “X”. Then I tried again, it worked (but make sure you select the object (“Rocket Asset”) as it might have been deselected).
        • The topic ‘I cant see assigned key frames’ is closed to new replies.
