I cant inset speaker circles, when i try to inset it becomes a triangle
Forum Archive I cant inset speaker circles, when i try to inset it becomes a triangle
  • #17727
    Nischal Choudhary
      Inset issue
      #85087
        Can you add some screenshots please Nischal @Nischal ?
        Without seeing anything, I’d say that maybe you have ‘Double Vertices’…in Edit Mode: try pressing A (to select everything), M > Merge > By Distance.
        #85088
          Screenshots is fine but it’s even better if you can record a screen grab. You also may be going over with the inset until it crumples on itself.
        • The topic ‘I cant inset speaker circles, when i try to inset it becomes a triangle’ is closed to new replies.
