I can’t get the fire to show up in a render :( I go to quick effects, the change it to fire. The smoke shows up but no fire, not sure what to do.
Forum Archive I can’t get the fire to show up in a render :( I go to quick effects, the change it to fire. The smoke shows up but no fire, not sure what to do.
  • #6559
    Zach Zellman
      Jonathan Lampel
        Hey Zach, I’m not sure what could be going on. Could you post a screenshot of your render and material nodes for the domain? I tried replicating by opening a new file, adding quick effects for fire and smoke, and it shows up in the render right away.
        #25575
        Zach Zellman
          I figured it out. I’m not sure what was causing it, but for some reason when I switched from smoke to fire the nodes wouldn’t change. Maybe a bug in the version I had? Or just a glitch. Anyway, I updated to the latest version, then deleted the sim, and add a new one. It’s all working perfect now! Thanks!
        • The topic ‘I can’t get the fire to show up in a render :( I go to quick effects, the change it to fire. The smoke shows up but no fire, not sure what to do.’ is closed to new replies.
