I cant find the option for Denoising but
Forum Archive I cant find the option for Denoising but
  • #12795
    yogendraa
      there is one option of denoising data under Passes-> Data, are they same? Because my render Image had still a good amount of noise, (it took 3 mins for one image, damn, Its going to be hours for the final)
      #60505
        In 2.9 several  Render Denoisers can be found in the Render Tab:
        NLM is the ‘classic’ one that was used in the tutorial, I think. You might even have more options (if you have Optix,….). You can make a comparison to see which one looks better/ is faster…
        The Denoising Data is meant for the Compositor (you can add a Denoise Node in the Compositor after you’ve rendered all images).
        #60506
          Oh, and don’t forget to enable Adaptive Sampling (also under Sampling in the Render Tab), probably makes a huge (speed) difference in the rocket scene.
          #60507
          yogendraa
            Thanks, found it, Have optix too
            Taking around 3 mins per frame and NLM around 2 mins, guess overnight it is on NLM
            #60508
            Mark Manno
              Thanks again Spikey!
              #60509
              mellowguero123
                Thanks bud, super helpful!
              • The topic ‘I cant find the option for Denoising but’ is closed to new replies.
