I can’t change the ‘ball type’ in the UI panel either. Have someone come up with a solution? I have tried working on B…
Forum Archive I can’t change the ‘ball type’ in the UI panel either. Have someone come up with a solution? I have tried working on B…
  • #5909
    I can’t change the ‘ball type’ in the UI panel either. Have someone come up with a solution? I have tried working on Blender version 2.77 but the problem persists.
    #24557
    Wayne Dixon
      You will most likely have a warning in the top info bar with a button that says “reload trusted”.
      This will fix the issue.
      #24558
      Thanks for the info Wayne! Problem solved.
      #24559
      Jean Ibrahim
        thanks! I had the same issue
        #24560
        Leonardi Caraballo
          THANK YOU Wayne!
          Now I can animate happy!
          #24561
          Randy Monhollen
            This is great for the original file but doesn’t seem to fix it as a proxy rig
            #24562
            Wayne Dixon
              Are you getting any error messages in the top info bar?
              Also make sure you are running the script in the text editor, and that ‘auto run python scripts’ is active in the user prefs.
              (but I think you would have checked that already)
              If you run Blender with a console open you can sometimes get more information about things when they don’t go as planned.
              #24563
              Mashhood P
                Thanks, That fixes my problem
              • The topic ‘I can’t change the ‘ball type’ in the UI panel either. Have someone come up with a solution? I have tried working on B…’ is closed to new replies.
