I cant apply modifiers/ convert to mesh after choosing the keyframe
Forum Archive I cant apply modifiers/ convert to mesh after choosing the keyframe
  • #11563
    hjoucka
      when i try to apply the modifiers it gives an error: modifiers cannot be applied to a mesh with shape keys
      #55296
        I just confirmed that I too cannot apply modifiers on an object with shapekeys. However I am able to convert to mesh to functionally “collapse” the model + modifiers + shapekeys.
        Are you sure the convert to mesh option is giving you this error and not just the apply button in the modifier?
        #55297
        hjoucka
          Not able to convert to mesh. Convert to mesh option is not on the list. Hot key doesn’t work
          #55298
            Since 2.8 this particular hotkey has been removed. You can find it here:
            Or use the Search menu.
            If you right click on ‘Mesh from Curve/Meta/…” you can assign a hotkey to it, or you can put it in your Quick Favorites if you are using this often.
            #55299
            hjoucka
              Yup, got it! Thanks guys
            • The topic ‘I cant apply modifiers/ convert to mesh after choosing the keyframe’ is closed to new replies.
