I can not get the arms to move
Forum Archive I can not get the arms to move
  • #7352
    I selected the bicep but I could not get it to rotate. I even tried going into the graph editor and editing the key frames of each axis on the arm individually but still had no luck. Below is a link to a picture of the setup I have in Blender. Any idea what I am doing wrong?
    https://docs.google.com/presentation/d/e/2PACX-1vTpmOwcZrqTn-z80ksbQHaN4_9Pf8sXvhIBG79Iv9bjOCvRnZLVXBCRxoVmwZ4EXrCDMYeyu1jPo9iv/pub?start=false&loop=false&delayms=60000&slide=id.g3b0c458979_0_0
    #26934
    Wayne Dixon
      I reckon you have the arms set to IK.
      #26935
      Princess Ghastly
        I’m having the same problem and I’m not set to IK. The rest of it has worked perfectly. Any other ideas?
        #26936
        Princess Ghastly
          Going into the Vonn Bots Properties section and tweaking seems to fix.
          #26937
          Wayne Dixon
            In your image I can see that the arms are set to IK:1.0
            That means the arms are in IK mode.
            The properties panel is where you set these properties and the Layers panel is where you turn on/off the visibility 😉
          • The topic ‘I can not get the arms to move’ is closed to new replies.
