I am trying to scale up the radius of skin modifier, but when I am hitting CTRL+A I unselect the vertex. How can I scale i…
Forum Archive I am trying to scale up the radius of skin modifier, but when I am hitting CTRL+A I unselect the vertex. How can I scale i…
  • #5452
    michelblade
      I am trying to scale up the radius of skin modifier, but when I am hitting CTRL+A I unselect the vertex. How can I scale it up without this key shortcut?
      #23892
        If you changed the default CTRL + A key shortcut to something else, I don’t think you’ll be able to scale the radius of a skin modifier mesh. Another reason why I force myself to adhere to default key shortcuts.
        I recommend reverting your shortcut keys to default to get back that functionality with the skin modifier.
        #23893
        michelblade
          It was an issue with Interaction preset, you can choose it when you launch the blender. I choose Maya, because I work in it at work, but it was mistake, it does not work correctly.
          #23894
          duketogo
            I had the same symptom. I searched “skin resize” it had CTRL +A for hotkey.
            “Font select all” had CTRL +A hotkey too and had priority over skin resize. I think I didn’t set like that.
          • The topic ‘I am trying to scale up the radius of skin modifier, but when I am hitting CTRL+A I unselect the vertex. How can I scale i…’ is closed to new replies.
