I am having trouble with the mirror modifier on the pants when i apply it, it creates holes and vertices pointing out. I t…
Forum Archive I am having trouble with the mirror modifier on the pants when i apply it, it creates holes and vertices pointing out. I t…
  • #4695
    ohsnapholly
      I am having trouble with the mirror modifier on the pants when i apply it, it creates holes and vertices pointing out. I think I messed up earlier and now the two sides were not identical and that’s why the mirror modifier applied it funky. Not sure what to do to fix this?
      #22947
      izzyiznt
        Sounds like you might need to enable “Clipping” in the mirror modifier.
        #22948
        ohsnapholly
          i did enable clipping and i still have the problem
          #22949
          izzyiznt
            Reread your question; did you delete half of the pants before adding the mirror modifier?
            #22950
            ohsnapholly
              yes i did delete half the pants when adding the modifier.
              #22951
              ohsnapholly
                nevermind i figured it out thanks anyway!:)
                #22952
                izzyiznt
                  Yay 🙂
                • The topic ‘I am having trouble with the mirror modifier on the pants when i apply it, it creates holes and vertices pointing out. I t…’ is closed to new replies.
