I am having trouble closing the window (the hidden one) that can be closed using the “end” key. Because I am using Windows on a Macbook Pro the “end” key is changed to function + right arrow. However, I cannot get it to close the window.
No, I think he means he is working on a Macbook and to close and open Tools you use ‘T’, however to close and open the right hand Transform Tools, on a Windows you use ‘End’ but what is the key for this on a Macbook? (I’m having the same problem)
Author
The topic ‘I am having trouble closing the window (the hidden one) that can be closed using the "end" key. Because I am using Windows…’ is closed to new replies.
