I am following your course using a mouse and I can't seem to solve this issue: each time I use the inflate/deflate brush, …
Forum Archive I am following your course using a mouse and I can't seem to solve this issue: each time I use the inflate/deflate brush, …
  • #5437
    amseroeddda
      I am following your course using a mouse and I can’t seem to solve this issue: each time I use the inflate/deflate brush, the smooth brush reverts everything I did before. If I inflate an area , the smooth brush makes it deflated again. How can I solve this issue using the mouse? Thank you!
      #23862
        It sounds like your Smooth brush’s strength is very high. Unless you’re saying it’s a literal revert.
        To test, I recommend using snake hook to pull out a tenticle shape and then use the Smooth brush on it. If it goes right back to the way it was before then thats a problem I’ve not seen before..
        #23863
        amseroeddda
          Hello!
          You were right , the strength of the smooth brush was too high. I lowered it and then it worked just as it does in the video.
          Thank you!
        • The topic ‘I am following your course using a mouse and I can't seem to solve this issue: each time I use the inflate/deflate brush, …’ is closed to new replies.
