Is it normal render like this with cycles? I set the GPU only (AMD RX 570). Because, if I use the CPU the render is very slow, even when I use OPENCL. GPU is faster, but the result is this picture. With Eevee or Cycles by CPU, everything runs fine.
Is there something I can do here, to fix this, or I just set cpu+opencl?
