How to match arm position & rotation when Switching from FK to IK for the arm?
Forum Archive How to match arm position & rotation when Switching from FK to IK for the arm?
  • #11917
    judisak
      Is there any technique or trick to match the arm position & rotation when switching from FK to IK? Thanks.
      #56387
      Wayne Dixon
        Hi Judisak,  I don’t have any tricks to matching when switching.  I didn’t build snapping into the rigs.  But here’s some advice for doing it by eye.
        -Make sure you key both the IK and FK on the switch.
        -switch over 1 frame (key both IK and FK on both frames as mentioned above)
        -try to avoid switching at all and stick with either IK or FK on that body part for the entire shot (probably not possible in this circumstance)
        -try to switch during a move so it is easy to flip the frames and match the motion – OR
        -try to switch when it is perfect still, so when you flip the frames you can see when it isn’t matching and tweak it easily.
        (The last 2 tips depend on the situation.  1 way is usually easier in different shots)
        Hope that helps.
        #56388
        judisak
          Thank you so much, Wayne for the tips. It does help.
        • The topic ‘How to match arm position & rotation when Switching from FK to IK for the arm?’ is closed to new replies.
