How to fix the particles bugs?
Forum Archive How to fix the particles bugs?
  • #16212
    Tudor Andrei
      Hello, I just follow the Low Poly Rocket tutorial and everything works well until the rendering part. When I’m running the animation on Blender, it looks good, no bugs… but when I’m rendering it, looks like this: https://we.tl/t-vSl62YDIVN
      Can someone tell me what kind of settings I should modify to fix it, please?
      #78572
      Adrian Bellworthy
        Houston, we have a problem!
        You say it only happens in the render, not in the viewport?
        Did you adjust any settings, like the velocity, before rendering?
        The viewport particle animation is cached to memory, to speed up the viewport play back.
        If you changed anything without re-caching there will be differences.
        Its hard to determine what the exact cause is from a video, if you can share the .blend file we can take a look and diagnose the issue.
        My first guess is the velocity, did you set keyframes on the velocity setting?
        It could also be a GPU issue, make sure your GPU drivers are up to date.
        You can share the .blend file with Google Drive or Dropbox or similar and post the link here.
        #78573
          Hi @2Dy ,
          did you Bake the Particles before rendering?
          See also:
          https://cgcookie.com/community/14831-render-issue-particles-flying-all-over
          #78574
          Tudor Andrei
            Thanks for the support and advices guys!
            In the end, the problem was with the bake particles indeed, as @spikeyxxx already said.
            #78575
              Dangs if you asked me that was kinda cool. I’d stick to that one. Put some sound and some cool music with a beat every time the smoke particles make a bang.
            • The topic ‘How to fix the particles bugs?’ is closed to new replies.
