How to edit object basic settings after transformed?
Forum Archive How to edit object basic settings after transformed?
  • #15419
    fgh dfgh
      How to edit basic settings of an object for example Cylinders (Vertices, radius, depth etc) after cylinder got moved or rotated or scaled. Thanks.
      #75424
      Jonathan Lampel
        That’s actually not possible in Blender, at least with the basic primitives. It’s possible via geometry nodes primitives, but that’s a topic for another day.
        #75425
          Like JL says, once you commit to an object setting, that is it. But it’s really not that big of a deal, because the settings are very basic and you don’t get very far into doing what you have to do if you decide the settings should’ve been something else.
          It’s not like in real life when you decided to study medicine and 8 years in you realized it’s not your thing. It’s more like you ordered a hotdog with fries and then you realized you didn’t want any fries with it.
          #75426
          fgh dfgh
            Thanks to both for taking time to reply.
            #75427
            Austin Dunham
              If you haven’t done too many other things there’s always undo until just before the modification, then redoing the modification.
            • The topic ‘How to edit object basic settings after transformed?’ is closed to new replies.
