How to cut a hole in a mesh
Forum Archive How to cut a hole in a mesh
  • #7810
    No No
      Let’s say I had a railing and I wanted to extrude the posts from the railing itself, how would I go about cutting a circle-like geometry into the face of the railing to extrude a post? Is this an okay practice or is there a better way?
      #27687
      Jonathan Lampel
        Hey Cameron, it depends on how thick the railing is compared to the posts, but you could add loop cuts about the width of the posts, inset, turn that inset into a circle, and then extrude it outwards, or you could just stick them through each other and not connect them at all if the camera won’t be seeing them up close.
        #27688
        tanaka
          You can also use a Boolean modifier and choose operation difference and subtract a cylinder or a cube to cut a hole…
        • The topic ‘How to cut a hole in a mesh’ is closed to new replies.
