Hello, I have two separated meshes:
Mesh A: a head without her mouth. Since there is no mouth, this leaves a huge hole on her head.
Mesh B: her mouth
From the back view, you can see the mouth mesh is a non-manifold as well. So it is not a closed mesh, but a single layer of mesh, and the edge of the mesh do not connect anything.
I want to combine the two meshes into one single mesh.
Some Methods I was trying:
I have tried to use “Ctrl + j” to join the meshes, and in the Edit mode, select the corresponding edges and press “f” to build new faces to connect the two meshes. But the result is a failure, since it automatically builds some unwanted new faces and meshes, as the following screenshots show:
By the way, using the Union in the Boolean modifier is also hard to work. The result can leave some spikes or many disconnected tiny meshes inside of her head. Those unwanted meshes can cause trouble for future sculpting.
Thank you for reading!
