How to change the rotation of the thumb.
Forum Archive How to change the rotation of the thumb.
  • #19985
    Santiago Acosta
      Hey guys! any clue why the thumb is rotating in the wrong direction? I’ve tried rotating and recalculate the roll but nothing seems to work.
      #94183
      Wayne Dixon
        Hi Santiago,
        I can’t tell exactly from the image but the first thing I would do is make sure that the bone roll is pointing in the correct direction.
        This doesn’t mean just recalculating it, but rather rolling it to point in the right way.
        The Z axes should all point towards the direction you want it to bend (I can’t tell exactly from your image)
        This includes the MCH bones etc
        The Next thing to check is that the transformation constraints are correctly setup on the MCH bones.
        Scale Y [0.5, 1.5] extrapolation on –> Rotation X source –> Y [90,-90]
        Notice how the minimum is positive and the maximum is negative. That will reverse the direction.
        Also make sure you are going from Local to Local space
        Failing those ideas, post it as a submission and I will take a look.
      • The topic ‘How to change the rotation of the thumb.’ is closed to new replies.
