How should I create a dark prismarine texture?
Forum Archive How should I create a dark prismarine texture?
  • #10349
    William Miller
      How can I make a texture that looks like the dark prismarine block (from Minecraft), except more realistic?  I was thinking of modifying this texture, but simply changing the color looks weird, even if I use a noise texture.
      For context, the scene it will be in will be at night, with a grassy path.
      #45854
      William Miller
        To clarify, I do not have Substance Painter.  Also, I changed my mind about the grassy path.  I’ve decided to make it dirty/muddy.
        #45855
          @williamatics Hi William, personally, I would use a procedural texture for something like this. I am not sure what you want exactly, but with a set-up like this for instance, you have a lot of tweaking possibilities to get what you want (I hope).
        • The topic ‘How should I create a dark prismarine texture?’ is closed to new replies.
