how do you switch between RGB and CMYK in Photoshop? Or do you mean i should use lighter hues when the intention is to pri…
Forum Archive how do you switch between RGB and CMYK in Photoshop? Or do you mean i should use lighter hues when the intention is to pri…
  • #5548
    Nicole Peterson
      how do you switch between RGB and CMYK in Photoshop? Or do you mean i should use lighter hues when the intention is to print later?
      #24007
      Tim Von Rueden
        You can switch by going to the Top Menu Bar > Image > Mode > RGB or CMYK. It’s hard to see the difference at first but you’ll notice the difference if you print something =]
      • The topic ‘how do you switch between RGB and CMYK in Photoshop? Or do you mean i should use lighter hues when the intention is to pri…’ is closed to new replies.
