How do I get the animation paths in the graph editor to match?
Forum Archive How do I get the animation paths in the graph editor to match?
Viewing 10 posts - 1 through 10 (of 10 total)
  • #15579
    Craig Wieland
      I want to get the spacing the same with the ball traveling down to match the spacing going up. I am using the Graph editor and scaling the handle to match frame 11, but when I do this it will not match frame one. What can I do to make the up and down animation path identical?
      #76056
        Hi @CCWieland ,
        I think you made a mistake in counting: Frame 1 is up, Frame 12 is down, that would mean the next top is on Frame 23 (you have it on 24) and the next down on Frame 34 (you are on 35)….
        #76057
        Craig Wieland
          Thank you.
          #76058
          tanya
            Hi –  I know Martin answered your question, but this might help in the future.  You can set the handle values using using F-Curve in the graph editor.
            Also it is sometimes easier to just work with the motion paths, to try to get the motion you. want.
            #76059
              Also if you want a keyframe to be the same in a given frame number, you can also Shift + D in the timeline to duplicate the frame and with G to grab, enter the number of frames you want that moved and they will be identical.
              #76060
              Craig Wieland
                Thanks you all, I appreciate the help. I am going to screen record to show you what I am attempting to do. I think that is the best way to ask.
                #76061
                Craig Wieland
                  here is my video question.
                  https://youtu.be/sFevC63h-rg
                  #76062
                    Hi @CCWieland ,
                    If you match the handles exactly, then you get what you want, but there are three keyframes that can influence the curve:
                    I think that your handles on keyframe 1  are not symmetrical/matching keyframe 25. If you have perfect symmetry in all your handles around frame 13, then the curves will also be symmetrical and therefore the Motion Path will match.
                    #76063
                      Your handles:
                      #76064
                      Craig Wieland
                        Thank you Martin that helped so much. Thank you as well Tanya, and Omar.
                        https://youtu.be/qLKHaZzHJig
                      • The topic ‘How do I get the animation paths in the graph editor to match?’ is closed to new replies.
