how do i get my ball to stop spinning at the same time as my tranlate?
Forum Archive how do i get my ball to stop spinning at the same time as my tranlate?
  • #15604
    puds luls
      https://www.youtube.com/watch?v=R-CJI0ekwBo
      its like it rotates a little after the ball comes to a stop and cant figure at how to get them in sync
      #76206
      puds luls
        they end on the same frame but it still rotates a little
        #76207
        tanya
          I am guessing the green line is the rotation.  Check the value of the handle on the right is the same as the key value.  I’m guessing it is different.  You can use the f-curve menu on right side of graph editor.
          #76208
          puds luls
            so i change the right handle to 108?
            rotate
            translate
            #76209
            tanya
              You want to change the value,  the key frame 108 has a. value 8.712, but. the right handle has a value of 8.708, so that is why it keeps moving, set it to  8.712 same as the key value.  Good luck.
              #76210
              puds luls
                tanya
                  looks good to me, you’ll have to see what Wayne says.  You’re doing great.
                  #76212
                  Wayne Dixon
                    Great eye @tanya53
                    Yes the handle isn’t flat so it will keep moving.
                    #76213
                    Craig Wieland
                      Forgive me this is my video blog for myself but it might help you.
                      https://rumble.com/v1sokzy-november-8-2022.html?mref=j96uv&mc=4w3v4
                    • The topic ‘how do i get my ball to stop spinning at the same time as my tranlate?’ is closed to new replies.
