How do i access the gizmo texture file?
Forum Archive How do i access the gizmo texture file?
  • #6926
    Michael Morrow
      The gizmo texture is not part of the exercise files How can i access it?
      #26201
        @mtmorrow – The gizmo’s textures are “packed” into the .blend file, meaning they’re included. So when you go to add the texture it’s simply available in the drop-down instead of importing the texture file externally.
        Can you confirm that the gizmo textures are available in the texture select list of the image texture node?
      • The topic ‘How do i access the gizmo texture file?’ is closed to new replies.
