How can I UV unwrap with subdivision modifier?
Forum Archive How can I UV unwrap with subdivision modifier?
  • #6366
    Marco Modena
        First, in the Subdivision Surface modifier you can enable “Subdivide UV’s” (though it should be enabled by default)
        Secondly, in the UV/Image Editor’s N-panel, under “Display” you can enable the “Modified” option to visualize what your UVs will look like when affected by modifiers.
      • The topic ‘How can I UV unwrap with subdivision modifier?’ is closed to new replies.
