How can I rig a Rubik’s cube?
Forum Archive How can I rig a Rubik’s cube?
  • #14111
    William Miller
      I was trying to rig a Rubik’s cube when I discovered that an object cannot have more than one parent.  How can I allow a tile to be controlled by multiple centers, and how can I transfer control when it shifts?
      #69270
      Adrian Bellworthy
        Hmmm,
        This has got my brain ticking @williamatics .
        I’m sure @waylow could come up with something. It seems relatively straight forward until you take into account different rotations.
        A corner for example would need 3 different pivot points.
        3 bones parented to one face bone, no , 3 tile bones parented to one cube bone parented to a face bone ,  hang on I still thinking……
        #69271
        William Miller
          Wait.  I could just set each piece’s origin to the center of the cube.  Then I could just rotate all the pieces around a single axis.
          #69272
          Parker Bourassa
            I think that’s the easiest way. Not a true “rig” in the typical sense, but good enough for a simple animation.
            #69273
            Wayne Dixon
              Rigging a Rubix’s cube is very complicated.
              I’ve never had to do it, but I think Parker is right.
              The easiest way to “get it done”, is not to have a rig, just animate the objects.  (in Quaternion mode because Gimbal lock is highly likely).  But make sure each object’s origin is actually in the centre of the “Rubix’s Cube”.
              I might be imagining things, but did I see a Rubix’s Cube with “Geo Nodes” recently?  I could have imagined it haha.
              Maybe it would be possible??  But you might end up having to animate the vector values on nodes.
              Every solution I can think of requires some kind of python scripting to dynamically transform the correct objects in the correct way.
            • The topic ‘How can I rig a Rubik’s cube?’ is closed to new replies.
