Hmmm… changing Emission > Bursts > Time doesnt seem to have any effect
Forum Archive Hmmm… changing Emission > Bursts > Time doesnt seem to have any effect
  • #5372
    jankovalsky
      #23760
      Jonathan Gonzalez
        It’s based on a specific time of the particle effect. If you have the duration set to 5 seconds you could set the time for the burst at 2 seconds and when the particle effect is at 2 it’ll create the burst. This allows you to time specific bursts to happen at a specific time within the particle effect.
        #23761
        jankovalsky
          Ok, so I cannot seen the difference because of the loop on.
          #23762
          Jonathan Gonzalez
            Try it without the “Rate over time” emission. Just use the burst. It’ll happen at the time you specify. So using the example above, set the time to 2 and it’ll burst every time at the 2 second mark.
          • The topic ‘Hmmm… changing Emission > Bursts > Time doesnt seem to have any effect’ is closed to new replies.
