High Poly file in Substance
Forum Archive High Poly file in Substance
  • #19497
    Fernando Hildt
      I decide to do this in Substance, since I got it for free a couple of months, I’m trying both tools. Where should I connect the High Poly file?
      #92511
        Hi @Selectiv0 ,
        I don’t have SP, nor any experience with it, but Chunck used it in his Course Tread. Maybe it’s enough to start from here: https://cgcookie.com/lessons/exporting-from-blender-importing-to-substance-painter  to see how this is done in Substance…
        #92512
        Chunck Trafagander
          Hey @Selectiv0, to hook up your High poly in the file, all you’ll need to do is click on the little file icon under the High Poly Parameters section from the image you provided! It’s a little hidden, I will admit. And like Martin said, if you are stuck on any Substance Painter related things, I do have another course where we create a game asset using Substance Painter so there may be tips there that you can glean!
        • The topic ‘High Poly file in Substance’ is closed to new replies.
