hidden faces are not hidden when i switched in sculpt mode
Forum Archive hidden faces are not hidden when i switched in sculpt mode
  • #12602
    Roman Bronnikov
      I selected faces in edit mode and hid unselected faces, but when I pressed TAB in sculpt mode the figure is not hidden (time in video 11:55)
      #59712
        Ahh nuts, you are correct. This functionality has changed with 2.9 with the introduction of Face Sets. Instead you can make your edit-mode selection into a face set and tell Sculpt Mode to only modify said face set:
        #59713
        Roman Bronnikov
          Thank you sir!
          But I just reinstalled 2.83 version )))
          #59714
            I 100% approve of this idea. If only to smoothly finish the course and translate the understanding later to the new version. It’s a good learning option 👍
            #59715
            Justin Kavoussi
              Just FYI in case anybody comes across this and is confused, the previous functionality has returned – tested in 2.91 and 2.92 and face hiding between Edit & Sculpt modes once again works just like in the video.
              #59716
                Ooo that’s good to know @jkavoussi – Thanks for posting for clarity  🤝
              • The topic ‘hidden faces are not hidden when i switched in sculpt mode’ is closed to new replies.
