Hi, when trying to create the skin modifier I keep getting an error that says "No valid root vertex found (you need one pe…
Forum Archive Hi, when trying to create the skin modifier I keep getting an error that says "No valid root vertex found (you need one pe…
  • #5443
    Daniel Marti
      Hi, when trying to create the skin modifier I keep getting an error that says “No valid root vertex found (you need one per mesh island you want to skin)” … I followed step by step the directions from the video, but I can’t get that working. Any idea what am I doing wrong? Thanks 🙂
      #23874
      Daniel Marti
        I was using Blender 2.77, I downloaded 2.75 and now looks like is working properly.
        #23875
          Hmm, I’m not sure I’ve ever seen that error when using the Skin Modifier. Thanks for sharing the fact that the error seems fixed in 2.77!
          #23876
          Rubén López
            I get the same warning with 2.77a. It appears when you have a mesh with only one vertex. After extruding the vertex the warning goes away an you con continue working.
            #23877
            Joshua
              Suddenly getting the same error. Was working fine exactly as Kent showed in tutorial. Went back to build another base mesh and suddenly having same problem. I’m using v2.78a. Any thoughts? Thanks! Here’s a quick video of what I’m doing: https://www.screencast.com/t/2vwmReqAw
              #23878
              Joshua
                Okay – working again – per birkov above, once you extrude your first point the warning goes away. I had trouble even extruding until I realized I needed to be in “vertex select” in edit mode.
                #23879
                galledark
                  Hey i’m with the 2.79 version.
                  Here’s the solution to fix the problem:
                  If you only have one vertex, and try to add the modifier, the error will appear.
                  I think blender is looking for at least 2 vertex to defne one as a root and the other one as the extruded vertex.
                  So:
                  1°) Make sure you have the vertex mode active !
                  2°) Add a single vertex in object mode, go in EDIT mode and extrude it.
                  3°) Add the skin modifier.
                  You’re first vertex will be the root.
                  Or:
                  The error will be here but just extrude the vertex and it will goes off.
                  (NB: the extuded vertex will be the root and will follow your extrusion.)
                  #23880
                    Thanks for sharing a solution @galledark!
                  • The topic ‘Hi, when trying to create the skin modifier I keep getting an error that says "No valid root vertex found (you need one pe…’ is closed to new replies.
