Hi, when I use the perspective views, I don't see perspective lines. Instead I see a straight on flat view of the cube. Ho…
Forum Archive Hi, when I use the perspective views, I don't see perspective lines. Instead I see a straight on flat view of the cube. Ho…
  • #4115
    raboto
      Hi, when I use the perspective views, I don’t see perspective lines. Instead I see a straight on flat view of the cube. How would I fix that?
      #22021
      raboto
        It seems that orbiting with the mouse helped fix it (middle mouse + click drag). Otherwise I was getting a similar view with perspective and orthographic views. Switching between ortho and pespective several times fixed it at other times too.
      • The topic ‘Hi, when I use the perspective views, I don't see perspective lines. Instead I see a straight on flat view of the cube. Ho…’ is closed to new replies.
