Hi when I select a line of the ear and select similar seam it outlines every seam I have previous done, include the split …
Forum Archive Hi when I select a line of the ear and select similar seam it outlines every seam I have previous done, include the split …
  • #4439
    Lloyd Farrell
      Hi when I select a line of the ear and select similar seam it outlines every seam I have previous done, include the split down the monkey’s head. How do I just select the ear and cancel out everything eise?
      #22538
      Hi, lloydfarrell. I’m a beginner so I’m not sure but I think this is the normal behavior of this action and it will always recognize every seam as similar, it also happens in the video. Since the only other seam is in the middle of the monkey’s head you won’t see any difference when it’s mirrored. On the other hand, if you select a non seamed line it will recognize every line in the monkey but the seamed lines will remain unselected. Hope it helps.
    • The topic ‘Hi when I select a line of the ear and select similar seam it outlines every seam I have previous done, include the split …’ is closed to new replies.
