Hi, when i add the "Empty" and I click on "offset object" the 2nd chain changes its size. When I scale the chain only the …
Forum Archive Hi, when i add the "Empty" and I click on "offset object" the 2nd chain changes its size. When I scale the chain only the …
  • #5515
    Martin Starchel
      Hi, when i add the “Empty” and I click on “offset object” the 2nd chain changes its size. When I scale the chain only the first objet changes its size… what went wrong?
      thanks
      #23967
      chris-ho
        I had this same problem. CTRL+A fixed it right away. Thanks!
      • The topic ‘Hi, when i add the "Empty" and I click on "offset object" the 2nd chain changes its size. When I scale the chain only the …’ is closed to new replies.
