Hi, What key do you use to set the offset value at 03.09? When I press "I" it just gives time the insert key frame menu,
Forum Archive Hi, What key do you use to set the offset value at 03.09? When I press "I" it just gives time the insert key frame menu,
  • #5350
    Hardus Jonker
      When I press “I” it just gives time the insert key frame menu,
      #23735
      Hardus Jonker
        Whoops I meant at 01:36
        #23736
        David McSween
          Sure sorry, you use the i key to add keyframes when hovering over values. This tutorial assumes that the user has a good knowledge of the Blender user interface. Thanks so much for watching!
        • The topic ‘Hi, What key do you use to set the offset value at 03.09? When I press "I" it just gives time the insert key frame menu,’ is closed to new replies.
