Hi Kent, When I try this on one of my examples with either the Alpha Over or the Mix node I only see the latest render la…
Forum Archive Hi Kent, When I try this on one of my examples with either the Alpha Over or the Mix node I only see the latest render la…
  • #5065
    pavelsputnik
      Hi Kent,
      When I try this on one of my examples with either the Alpha Over or the Mix node I only see the latest render layer (i.e. the Orb in your example) but not the two others. If I move the Fac slider to 0.5 in both nodes I can see all three layer but they look somehow dampened.
      Any idea what I did wrong?
      #23402
      pavelsputnik
        Nevermind, I found out myself. There were 2 things missing:
        1. I forgot to set the World background to Transparent in the Render tab (as shown in a previous lesson ^^)
        2. I had to reassign the Alpha Channel of the top render layer to the Alpha Over node.
      • The topic ‘Hi Kent, When I try this on one of my examples with either the Alpha Over or the Mix node I only see the latest render la…’ is closed to new replies.
