Hi Kent, I'm using grease cut but it's not working correct. It either deletes the whole piece or cut it successfully but l…
Forum Archive Hi Kent, I'm using grease cut but it's not working correct. It either deletes the whole piece or cut it successfully but l…
  • #4968
    yishi
      Hi Kent, I’m using grease cut but it’s not working correct. It either deletes the whole piece or cut it successfully but leave the mass hollow inside. I tried your suggestion on closing the stroke still not doesn’t work. Do you know any way to fix the problem? I’m stuck right now since so many pieces in the video are created by grease cut. Thank you!
      #23292
      Stanley Leland
        I found cleaning up the mesh using Remesh in the Sculpt tools helped. Not a magic bullet but it worked for me.
      • The topic ‘Hi Kent, I'm using grease cut but it's not working correct. It either deletes the whole piece or cut it successfully but l…’ is closed to new replies.
