Hi Kent, i'm using Blender 2.78. I notice if I deselect object or faces in edit mode, (for example When I select and mark …
Forum Archive Hi Kent, i'm using Blender 2.78. I notice if I deselect object or faces in edit mode, (for example When I select and mark …
  • #4470
    Federico Violin
      Hi Kent, i’m using Blender 2.78. I notice if I deselect object or faces in edit mode, (for example When I select and mark seam) my unwrap desappear in the UV editor. I need to select and unwrap a new time for see it again. What is the way to “hold” the last unwrap while I work in the object and selections in edit mode? Thank you very much in advance!
      #22596
      rhyhorn277
        You can active the option “Keep UV and edit mode mesh selection in sync” at the bottom menu bar of UV editor.
      • The topic ‘Hi Kent, i'm using Blender 2.78. I notice if I deselect object or faces in edit mode, (for example When I select and mark …’ is closed to new replies.
