Hi Kent, excellent job as usual… Why are you scaling the left eyeball manually to match the reference instead of using …
Forum Archive Hi Kent, excellent job as usual… Why are you scaling the left eyeball manually to match the reference instead of using …
  • #5566
    Javier Martí
      Why are you scaling the left eyeball manually to match the reference instead of using x symmetry? Are you not expecting issues if you change the camera angle?
      #24034
        Hey thanks for positive feedback 🙂
        Unfortunately with this ‘xeroxing’ workflow it’s highly unlikely that symmetry is true in the artwork. So if we’re going to match it perfectly we have to stray from symmetry. The goal though, as a 3D artist/sculptor, is to achieve a balance and make sure the asymmetry looks ok from other viewing angles.
        #24035
        Javier Martí
          ok, thanks. I have to try your method. The eyes and the look of the character are always a struggle
        • The topic ‘Hi Kent, excellent job as usual… Why are you scaling the left eyeball manually to match the reference instead of using …’ is closed to new replies.
