Hi, adding grass to my terrain causes a significant dropdown in performance (FPS going way down). And I am not adding alot of grass to the scene. Any advice on what I have to consider to increase my FPS again?
You probably do have a lot of grass you just don’t see it since Unity doesn’t show grass at certain distances. Zoom in closely on your terrain and look around. Also make sure you’re using very low poly (planes) grass and not something like 3d meshes which can drastically reduce performance.
Author
The topic ‘Hi, adding grass to my terrain causes a significant dropdown in performance (FPS going way down). And I am not adding alot…’ is closed to new replies.
